Date/Time: Wed, 04 Nov 2026 15:53:04 +0000
Sierra Chart Mac OS version
View Count: 3578
[2016-02-08 01:40:37]
User43684 - Posts: 4
Still nothing new?
[2016-02-08 02:13:30]
This is not an easy task. We would not expect something until 2017.
[2019-07-05 07:05:23]
Tony - Posts: 732
FYI, Wine also has a Mac version, I installed it on my MacBookPro and iMac, both now running SierraChart flawlessly (without Windows operating system) and fast! There is no issues for SierraChart to communicate with my Mac version IB TWS either. You do need to have a little bit Unix/Linux knowledge to set it up though (not many people are aware that Mac OS is a Unix system).
Run Sierra Chart on GNU/Linux, BSD, and Mac OS X using Wine
Linux
Date Time Of Last Edit: 2019-08-25 05:15:54
[2019-07-05 16:50:30]
That sounds good. But we really question whether everything is truly flawless.
[2019-07-05 21:53:08]
User138602 - Posts: 185
May i ask how far the developement of an MacOS version is?
[2019-07-06 01:48:18]
Support for the Mac OS has been canceled. We are gradually working towards supporting another operating system and most likely it would be Linux. But when that would happen we do not know.
Date Time Of Last Edit: 2019-07-06 01:48:50
[2021-01-14 07:21:55]
ganz - Posts: 1048
fyi.
CSV DB 1M lines
the task is to parse and to store next line to do some stats then
same i5 based HW
same clang 10
same code for C ver and C++ no STL ver
clang -O3 / clang++ -O3
macOS 10.13
pure C ver takes 467 ms to finish
C++ no STL ver takes 1170 ms to finish
Fedora 32
pure C ver takes 295 ms to finish
C++ no STL ver takes 307 ms to finish
macOS 10.13
XCode 10.1
ObjC using NSString * / NSArray * takes 2580 ms to finish
Date Time Of Last Edit: 2021-01-14 07:27:59
