Date/Time: Fri, 13 Nov 2026 07:19:28 +0000
Text labels on retracement drawing
View Count: 2008
| [2016-02-07 14:15:23] |
| @sstfrederik - Posts: 413 |
Hi, Are you planning on adding text custom labels to some of your drawing tools like the retracement tool? Thanks, Frederik |
| [2016-02-07 18:25:02] |
This is supported by using the Modify Text command: Chart Drawing Tools: Modify Text Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-02-07 20:00:24] |
I meant the on a drawing using the UseTool function in ACSIL. I am drawing a retracement that could use a text label.
| [2016-02-07 20:21:09] |
It is not supported to add custom text labels to the retracement levels for Price Retracement drawings. You would have to separately do this by using Text drawings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-07 20:21:25
| [2020-11-13 17:03:36] |
| whats1thingnow - Posts: 418 |
+1
