Date/Time: Wed, 28 Oct 2026 14:34:17 +0000
Chart end
View Count: 977
[2016-02-05 16:49:13]
User848740 - Posts: 12
I have two charts in Window. Same symbol different time setting.
Fill space about six bars wide locked.
Charts are always going to a few bars before the end. Red box in lower right corner.
Count down timer stops and goes to zero.
Ctrl End brings both charts to the end.
I have to do this continuously all morning.
Is there anyway to keep the charts locked at the "end"?
Fred
[2016-02-05 18:54:09]
Basically what you are describing is that you have scrolled back the chart from the end. There is no way to keep it at the end always.
Possibly one reason this is happening is that you have Tools >> Synchronize Charts enabled. Disable that.
