Date/Time: Wed, 28 Oct 2026 14:35:41 +0000
Data stopped again
View Count: 968
| [2016-02-02 20:11:24] |
| Matt654 - Posts: 73 |
SC Forex data stopped for US 30, ah just started again. Had to close all my trades, bit scary when it does that.
| [2016-02-02 20:15:18] |
We are checking on this now.
| [2016-02-02 20:18:15] |
We have confirmed that this was an interruption with the data feed from FXCM. It is out of our control. Consider using the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed And activating the Dow Indices Exchange. You can then use the symbol $DOWI to get realtime data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-02 20:18:50
