Date/Time: Wed, 28 Oct 2026 14:35:42 +0000
Setting to flatten at end of day session in auto trade system
View Count: 1418
| [2016-02-02 00:12:53] |
| User68474 - Posts: 204 |
Is there a way to adjust settings to effect "flatten" and "cancel all" at the end of a day session when using Auto Trading ?
| [2016-02-02 02:06:33] |
Not automatically. You need to program this. Are you using Spreadsheets or the Advanced Custom Study Interface and Language for automated trading? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-02-02 03:05:24] |
Custom Study
| [2016-02-02 04:27:43] |
Therefore you need to use this function: Automated Trading From an Advanced Custom Study: sc.FlattenAndCancelAllOrders This code example here may help you: http://www.sierrachart.com/index.php?page=doc/doc_ACSILProgrammingConcepts.html#ActionWhenCertainTimeIsEncounteredInMostRecentBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
