Date/Time: Wed, 28 Oct 2026 14:35:02 +0000
MT4 servers
View Count: 1594
| [2016-02-01 19:40:37] |
| User507693 - Posts: 9 |
do you have any plane for adding MT4 servers or any Api exist to connect your platform to mt4 servers? can you send me some education about you platform auto trade programming? thanks for your good support |
| [2016-02-01 20:07:55] |
Refer to the response here: multi connection at same time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
