Date/Time: Wed, 28 Oct 2026 14:35:04 +0000
Different data for same data feed
View Count: 1197
| [2016-02-01 19:37:00] |
| User967674 - Posts: 1 |
Hello SC, I've compared my charts with other traders and found that some of my bars (high/low) and volumes are different in compare with other traders. It is interesting that we all have same broker and same data feed (CQG). Please see attached screenshots with highlighted volume areas and comments in yellow. Can this problem be caused, that I currently use Replay mode for trading and other two traders are trading live? We have same setting in Data/Trade Service Settings. Thank you very much for help. Best regards, Jiri |
Private File Private File Private File |
| [2016-02-01 19:43:32] |
Refer to help topic 43: Http://www.sierrachart.com/index.php?page=doc/helpdetails43.html It is not related to chart replays. We cannot provide further help with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
