Date/Time: Wed, 28 Oct 2026 14:34:14 +0000
how to enter a symbol on that same chart and to get my replay records back to that chart.
View Count: 984
| [2016-02-01 03:23:12] |
| idcisosf - Posts: 34 |
Hi, I have a chart opened with my replay records on the chart, when I tried to change time frame, somehow the symbol got deleted. So, my question is how to enter a symbol on that same chart and to get my replay records back to that chart. And how to use a new chart to put replay records to that new chart? Thanks, |
| [2016-02-01 05:30:57] |
Did you change the chart bars timeframe by just typing the time period directly into the chart window? You can set the symbol through Chart >> Chart Settings >> Symbol . You can open a chart through File >> Find Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-01 05:31:09
