Date/Time: Wed, 28 Oct 2026 13:34:28 +0000
Gene
View Count: 985
| [2016-01-30 13:43:06] |
| User72965 - Posts: 116 |
I can't make Replay work ???? Sending an image..... Thx Gene Am hooked up to feed ... http://www.sierrachart.com/image.php?l=1454161199803.png you may not see the window asking to clear trade info. from Sim. 1 ?? What I get when I try replay. After I say yes or no (tried both ways) The Play Stop boxes turn black, means should work.. Then the stop graey out <> Nothing ??? |
| [2016-01-30 18:38:23] |
Follow through the instructions here: Replaying Charts: Basic Chart Replay Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
