Date/Time: Wed, 28 Oct 2026 13:34:12 +0000
Will my Sierra and a brokerage demo Sierra be ok together ?
View Count: 955
[2016-01-29 17:13:41]
User133711 - Posts: 9
I have a Sierra account that I use with Interactive Brokers. I now want to open a demo account at AMP brokerage using their Sierra demo platform. I asked AMP tech support if my computer would be able to distinguish between the two versions of Sierra or would there be a problem. He said he wasn't sure and that I should ask Sierra. Hope someone can advise me. Thanks.
[2016-01-29 18:19:25]
You can run two copies of Sierra Chart on your system. This will not be a problem but you need to maintain your own direct Sierra Chart account to be able to use Interactive Brokers.
Refer to:
Using Multiple Data and Trading Services at the Same Time
