Date/Time: Wed, 28 Oct 2026 13:34:24 +0000
H/L in Study RTH
View Count: 1003
[2016-01-29 02:19:42]
Crtfyd - Posts: 310
How can I get the Hi for the day (line), and Low for the day (Line) in RTH in a study?
My chart is Session time 9:30:00-11:00 and evening session 2:00-9:29:59
So I'm able to apply the "Daily OHLC" study to my Main chart (using day session only)and achieve the ongoing H/L for the day from the open of 9:30 BUT...
Nothing works on a study. When I apply the "Daily OHLC" study, it only draws the open line from 9:30, but the H/L read zero and don't show. "Hi/Lo for Time period" doesn't work on a study either.
My studies, if it makes a difference, are "Cumulative Sum of Study" and "Trade Volume"
[2016-01-30 03:54:09]
One way you might be able to do this is documented here:
https://www.sierrachart.com/index.php?page=doc/doc_StudyPriceOverlayStudy.php#OverlayStudyDiffSessionTimes
The method you are using has no guarantee it would work. If it does not work, then it does not work and we are not going to help with that.
Date Time Of Last Edit: 2016-01-30 03:54:41
