Date/Time: Wed, 28 Oct 2026 13:34:24 +0000
Countdown Timer from one chart superimposed on another chart
View Count: 1251
| [2016-01-28 22:02:33] |
| User94740 - Posts: 333 |
I know the study/price overlay fails to work on this study. Is there any other possibilities or something foreseen?
| [2016-01-29 01:34:12] |
| Sawtooth - Posts: 4358 |
It could be done using the Spreadsheet Study study on the source chart, and the Text Display for Study From Chart study on the destination chart. You can use, or modify, this study: http://www.sawtoothtrade.com/free-stuff-11.html It works with time-based, #trades, volume, and range bars. Reference columns O, P, Q, or R in the Text Display study. The only limitation is that time based bars greater than 60 seconds will display in total seconds, not minutes and seconds. |
