Date/Time: Fri, 11 Sep 2026 21:38:52 +0000
Formula for Alert
View Count: 923
| [2016-01-28 19:24:34] |
| nicktrader - Posts: 811 |
Is it possible to use in a formula a Short Name of a study instead of the ID reference Example =L>ID2.SG1+10, Instead of "ID2.SG1" I'd like to use "EMA10". There is one problem. In one chart EMA10 has the ID2, in a second ID5 and in the third ID7. Each time you have to adjust the formula. In all my charts the EMA010 has the same ShortName. If I could use the Short Name, it would be much easier. |
| [2016-01-28 19:56:59] |
No, this is definitely not supported. This is something that would never be supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
