Date/Time: Fri, 11 Sep 2026 21:39:29 +0000
vs 1360 -Time Line
View Count: 1174
| [2016-01-28 16:29:19] |
| Crtfyd - Posts: 310 |
I have "time line" studies to my graph on my study and main charts. I downloaded vs 1360 yesterday and noticed this this morning. The problem is the time line shows up before the time and moves with each new bar until the designated time is reached thereby giving a false signal. Eg: I have a 6 second chart and have the "Time line" studies set for (9:29:54 ,the open, so the line doesn't cover the first bar of RTH). I open my SC charts this morning at 9:10 and the time line shows up on each new bar moving right until the designated time. You can imagine I freaked out thinking it was the open and had to double check to make sure my laptop clock was correct. |
| [2016-01-28 19:50:57] |
Refer to the updated documentation here for this study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s181 Check all of the Input settings to make sure they are correct. There have been some recent changes to this study. We also made another change to this study this morning to resolve another issue. Not sure if that is relevant in your case though but nevertheless, update to the latest prerelease following the instructions here: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
