Date/Time: Fri, 11 Sep 2026 21:39:18 +0000
Interactive Brokers - order not filled - YM
View Count: 1911
[2016-01-28 14:45:51]
Kefir - Posts: 34
today around 8:36 I placed limit at 15970. Market went briefly below the price (with also ask being below) but my order was not filled.
I will provide you with the log if you tell me how to get it after I have restarted SC and IB (it was my priority before writing to you)
Regards
r.a.
[2016-01-28 17:35:54]
Are you sure the order did not fill?
Refer to:
Notice: Important Update for Interactive Brokers Users | Post: 74190
Although the version you are running already has this problem solved.
If you are referring to a non-simulated order which did not fill, then you need to contact your broker/trading service about this. We cannot help with that if the order had an Open Status.
Date Time Of Last Edit: 2016-01-28 17:37:10
