Date/Time: Fri, 11 Sep 2026 22:22:29 +0000
Alert Manager - File/ Save Log to file
View Count: 926
| [2016-01-28 05:51:39] |
| nicktrader - Posts: 811 |
There is the option to save the log of the "Alert Manager". Is there a way to open a saved file and work with it (e.g. "Go to chart")
| [2016-01-28 06:41:50] |
No. There is no ability to import the data.
