Date/Time: Fri, 11 Sep 2026 22:22:29 +0000
Control the chart tick size setting from within spreedsheet
View Count: 1212
| [2016-01-27 23:41:39] |
| User33781 - Posts: 5 |
It would be extremely useful if I could Control the chart tick size setting from within the spreadsheet. I have to calibrate the chart tick setting by hand as a stock goes up a few dollars, of for a $5 stock, compared to a $50 stock. Is there a study that can control the chart tick size, or better yet can Sierra Chart add a cell in the J column that controls chart tick size?
| [2016-01-28 03:26:31] |
This can be done with ACSIL: Advanced Custom Study Interface and Language (ACSIL) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
