Date/Time: Fri, 11 Sep 2026 22:21:26 +0000
Renko
View Count: 903
| [2016-01-27 22:13:58] |
| User848740 - Posts: 12 |
How does the bar time period selected affect the Renko Chart. If I select a 30 min time frame I get a different chart than a five min bar time Renko charts are not supposed to be time sensitive but are only based on price movement. Why aren't the charts the same? Fred |
| [2016-01-27 22:47:44] |
It sounds like you are using one of the Renko studies. Instead use the Renko Bar Period Type documented here: Renko Bar Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
