Date/Time: Fri, 11 Sep 2026 22:21:31 +0000
Data Feed :
View Count: 878
| [2016-01-27 20:49:27] |
| User22591 - Posts: 133 |
I have lost my data feed since earlier PM. Is there a problem on your side? Winston 770-645-9998 |
| [2016-01-27 22:46:42] |
You are using Interactive Brokers and not using a Sierra Chart provided data service, so this could not be a problem on our side but instead with Interactive Brokers. Refer to help topic 3.4: https://www.sierrachart.com/index.php?page=doc/helpdetails3.html#h3.4 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-01-27 23:38:37] |
I am sorry but the problem is on your side. I am getting data from Interactive Brokers. My API setting is correct. I have spoken with IB and they have checked all setting on there side. I do think the problem is your server. Yours Winston 770-645-9998 |
| [2016-01-28 00:11:44] |
You are not using any Sierra Chart real-time data services. There is no server problem. Restart Sierra Chart. Open one Intraday chart and no other charts. Once again open one chart and no other charts. After that provide a copy of the Message Log by following these instructions here: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Once again only open one chart. So do not open any saved Chartbooks. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-28 00:12:32
