Date/Time: Fri, 11 Sep 2026 22:21:24 +0000
Correct Scale settings to avoid constantly having to move the chart?
View Count: 1078
| [2016-01-27 19:48:17] |
| User40520 - Posts: 62 |
We have 3 Interactive Scale settings and 4 Scale Range settings. What is the correct combination of settings so the candles are always visible. Mine keeps drifting off and as I have a lot of charts it makes for constant sliding charts back into visibility.
| [2016-01-27 23:01:53] |
Refer to: https://www.sierrachart.com/index.php?page=doc/helpdetails46.html Disable Global Settings >> Tool Settings >>Support Vertical Scaling/Movement with Hand Tool. And do not use Interactive Scale Move. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
