Date/Time: Fri, 11 Sep 2026 22:21:32 +0000
Can't place order with IB - MNKD
View Count: 2514
| [2016-01-27 17:10:06] |
| Stephan908 - Posts: 46 |
Any idea how to fix this? Thanks. Trading message from IB: The price does not conform to the minimum price variation for this contract. Error Code: 110. ServiceOrderID: 328. | 2016-01-27 11:04:37 Trading message from IB: The price does not conform to the minimum price variation for this contract. Error Code: 110. ServiceOrderID: 329. | 2016-01-27 11:04:37 Trading message from IB: The price does not conform to the minimum price variation for this contract. Error Code: 110. ServiceOrderID: 330. | 2016-01-27 11:04:37 Trading message from IB: The price does not conform to the minimum price variation for this contract. Error Code: 110. ServiceOrderID: 331. | 2016-01-27 11:04:37 Trading message from IB: The price does not conform to the minimum price variation for this contract. Error Code: 110. ServiceOrderID: 332. | 2016-01-27 11:04:37 Trading message from IB: The price does not conform to the minimum price variation for this contract. Error Code: 110. ServiceOrderID: 333. | 2016-01-27 11:04:37 Interactive Brokers | Sent reqOpenOrders request | 2016-01-27 11:04:52 Trading message from IB: Can't find order with id =328. Error Code: 135. ServiceOrderID: 328. | 2016-01-27 11:07:45 Trading message from IB: Can't find order with id =331. Error Code: 135. ServiceOrderID: 331. | 2016-01-27 11:07:45 Trading message from IB: Can't find order with id =328. Error Code: 135. ServiceOrderID: 328. | 2016-01-27 11:07:46 Trading message from IB: Can't find order with id =331. Error Code: 135. ServiceOrderID: 331. | 2016-01-27 11:07:46 Trading message from IB: Can't find order with id =328. Error Code: 135. ServiceOrderID: 328. | 2016-01-27 11:07:46 Trading message from IB: Can't find order with id =331. Error Code: 135. ServiceOrderID: 331. | 2016-01-27 11:07:46 |
| [2016-01-27 17:28:40] |
What is the price that you specified for the order? Also select Trade >> Refresh Data Trade Data from Service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-01-27 17:40:16] |
I noticed the price quoting from IB is in .01 format instead of 0.0001 format. If I change the price display format to .01 and Tick Size to 0.01 instead of .0001 and 0.000100 it works. I have Auto-Set From Data Feed checked before. Unchecking that and manually changing the price display format and tick size fixed it. Is Auto-Set From Data Feed pulling data from Sierra or IB? Thanks.
| [2016-01-27 17:59:10] |
We do not recommend using Auto Set From Data Feed. When that is enabled, the settings are coming from Interactive Brokers. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-01-27 18:27:53] |
I see. Not sure if i enabled it or if it was default. Either way I will leave it disabled. Thanks for your help.
