Date/Time: Fri, 11 Sep 2026 22:21:25 +0000
Jump from Alert to Alert
View Count: 910
[2016-01-27 16:25:40]
nicktrader - Posts: 811
To get an alert for my specific pattern I use the study "Color Bar... Alert...". It works fine.
To analyse that pattern I have to go back in the past (e.g. last 6 month). The best way would be to jump from alert to alert.
The only way I found was using the "replay function" with a very fast speed (50,000) till end. Than I opened the Alert Manager and all Alerts were listed.
Is there an other way to jump from one alert to next?
[2016-01-27 18:23:21]
You can go from an Alert line in the Alerts Manager >> Alerts Log to the chart.
Seems so you are already aware of this.
There is no other way.
