Date/Time: Mon, 16 Nov 2026 23:54:21 +0000
ACSIL convert string to time
View Count: 5370
[2016-01-27 01:26:38]
@sstfrederik - Posts: 413
I am reading data from an external file, how can I read the a time string and convert it to SC time?
thanks
[2016-01-27 05:01:30]
Give us an example of the time string.
[2016-01-27 10:40:09]
I read a csv file and tokenize the line. i have an element in an array with string like "09:00pm". do i need to reformat it in the csv first and than do something with atoi or is there a simpler way?
thanks.
[2016-01-27 16:43:44]
Sierra Chart does not have the ability to work with a time format like that. It would have to be something like 09:00 or 09:00:00. There cannot be a.m. or p.m. The hours must be in 24-hour format.
[2016-01-27 17:05:46]
Thanks. I will reformat the cvs. Which SC function can work with the 24hr format string? I have only seen the string to date function.
[2016-01-27 18:57:00]
We are releasing a new version now, 1360, and it will have this new function:
double sc.TimeStringToSCDateTime(const SCString& TimeString);
[2016-01-27 19:11:31]
Great! Thanks.
[2016-01-28 23:24:29]
Example code that works.
SCString DateString ("2011-12-1");
SCDateTime DateValue;
DateValue = sc.DateStringToSCDateTime(DateString);
SCString TimeString ("17:00");
SCDateTime TimeValue;
TimeValue = sc.TimeStringToSCDateTime(TimeString);
SCDateTime DateTime;
DateTime.SetDateTime(DateValue, TimeValue.GetTime());
[2016-03-03 23:41:20]
The function is correctly supporting yyyy/mm/dd, but does not support dd/mm/yyyy instead it outputs mm/dd/yyyy. Can this be changed? Else be reflected in the documentation. Thanks.
Date Time Of Last Edit: 2016-03-03 23:45:45
[2016-03-04 09:27:00]
This function will be in the next release:
double sc.DateStringDDMMYYYYToSCDateTime(const SCString& DateString);
[2016-06-27 16:09:04]
ejtrader - Posts: 689
SC Team - Have the following 2 strings and wondering if this can be converted to "SCDateTimeMS" format.
DateString='2016-06-26'; // fixed width/digits --- YYYY-MM-DD
TimeString='22:34:03.005'; // fixed width/digits -- HH24:MI:SS.mmm - This includes the milliseconds.
Trying to create a variable that can be used as "SCDateTimeMS".
Appreciate any input on this.
thanks
Date Time Of Last Edit: 2016-06-27 16:13:19
[2016-06-27 21:32:37]
If this is not a straight forward conversion - would you please clarify on how many decimals to be used to store DataTimeMS into an external text file and retrieve it so that it can be used as a DateTimeMS variable? Looking to store as a double to string in text file and retrieve it.
[2016-06-27 22:10:25]
Use these functions:
ACSIL Interface Members - Functions: sc.TimeStringToSCDateTime()
ACSIL Interface Members - Functions: sc.DateStringToSCDateTime()
[2016-06-27 23:51:49]
Thanks SC Team.
I tried to use them with SCDateTime/SCDateTimeMS combination - in both the cases I am loosing the millisecond portion from the output. Do I have to any other functions to preserve the millisecond portion?
SCString DateString="2016-06-26";
SCString TimeString="22:34:03.005";
//Also tried with SCDateTime in place of SCDateTimeMS - but still missing milliseconds
SCDateTimeMS DateValue;
SCDateTimeMS TimeValue;
SCDateTimeMS DateTime;
SCString message;
message.Format("DateTime: %s", sc.DateTimeToString(DateTime, FLAG_DT_COMPLETE_DATETIME_MS).GetChars());
sc.AddMessageToLog(message, 0); // Got the output as DateTime: 2016-06-26 22:34:03.000
Date Time Of Last Edit: 2016-06-27 23:52:06
[2016-06-28 00:47:06]
You need to do it like this:
DateTime = DateValue + TimeValue;
[2016-06-28 01:55:40]
Thanks SC team.
For anyone looking for this in the future - this is the resulting code.
SCDateTimeMS DateTime = DateValue + TimeValue;
SCString message;
