Date/Time: Fri, 11 Sep 2026 22:21:27 +0000
RFH6, RYH6, RPH6
View Count: 1127
| [2016-01-22 17:57:20] |
| User438810 - Posts: 50 |
The cross rate fx futures markets aren't available but they're on CME. Is there a dload I need to do?
| [2016-01-22 18:14:21] |
We need to set these up for GAIN Capital. We will have this done next week.
| [2016-01-28 04:53:37] |
This is now done. Restart Sierra Chart to get the updated symbol settings.
| [2016-01-28 06:16:10] |
The historical charts work perfectly so thank you for that. However I'm still having trouble getting data for the intraday charts on all three.
| [2016-01-28 07:36:19] |
Go to the Intraday charts for the symbols and re-download the data with Edit >>Delete All Data and Download. You should now get the history. One of the symbols will have less than one week of history though. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
