Date/Time: Wed, 28 Oct 2026 12:55:45 +0000
SCdata
View Count: 1535
[2016-01-18 07:31:15]
TradingMarketProfile - Posts: 120
Hello
I just subscribe to your barchart data, i have the [M] on eurex chart (FGBL, but not enought data) but not on 6E 4 (see charts)
imagebund.png / V - Attached On 2016-01-18 07:30:47 UTC - Size: 188.03 KB - 467 views
imagebund2.png / V - Attached On 2016-01-18 07:30:54 UTC - Size: 190.04 KB - 419 views
image6e.png / V - Attached On 2016-01-18 07:31:01 UTC - Size: 112.07 KB - 379 views
[2016-01-18 07:58:29]
In all of these cases, you need to update the Symbol Settings as explained here:
Global Symbol Settings: Update Symbol Settings
After this is done, go to each of these charts and select Chart >> Reload and Recalculate.
Also refer to the documentation here:
https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#DisplayingRolloverDatesContractMonths
Date Time Of Last Edit: 2016-01-18 08:59:26
[2016-01-18 08:52:21]
i've done everything you said but still the same
[2016-01-18 08:58:20]
Therefore, follow the instructions here to re-download the data in the chart:
https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading
So actually the problem must have been that there is missing data and not missing Symbol Settings.
Date Time Of Last Edit: 2016-01-18 08:59:59
[2016-01-19 05:40:21]
So after trying everything, i still don't get the [M} on the CME symbols
I tryed on 6E, YM and ES it woks only on EUREX symbols
[2016-01-19 08:26:16]
We misunderstood the problem. The charts you showed us showed incomplete data towards the earlier part of the chart which indicated a problem with the creation of the Continuous Futures Contract chart.
But what you are clearly asking about in this latest message, is accessing the real-time data for CME symbols from the Sierra Chart Exchange Data Feed.
In this particular case go to this page:
https://www.sierrachart.com/usercp.php?page=SC_RealTime_DataFeed_SetExchanges
Activate the Full CME Group exchange for 3.25 USD per month and after that is done restart Sierra Chart.
