Date/Time: Wed, 28 Oct 2026 12:55:45 +0000
Spreadsheet Study - can't load more than 1000 rows
View Count: 1318
| [2016-01-16 02:43:04] |
| rhovega - Posts: 279 |
Hi, I can't increase the number of rows to load beyond 1000, even if I put more. Number of days is not the issue (1000 rows is just a few days). I am running version 1354. Please help. Thanks |
| [2016-01-16 17:38:55] |
You need to check to make sure that the Spreadsheet Study is on the chart and referring to the correct Spreadsheet and Sheet within the Spreadsheet where you want to see more rows. There must be something wrong with one of those. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-01-16 19:57:09] |
Thank you. solved. Same solution for both my last questions related to spreadsheet study (other was not outputting into chart). There's something I yet don't understand. Allow me to illustrate. I added a spreadsheet to chart #3. - If the study makes reference to sheet 0, anything (ie signals) I do in sheet 0 does not show up in the chart. - If the study makes reference to sheet 3, anything (ie signals) I do in sheet 3 gets deleted from the spreadsheet. - If the study makes reference to sheet other than 3 or 0, then it works. I thought the spreadsheet study should make reference to either sheet 0 (for sharing studies across instruments) or the same sheet # as the chart #. Thank you! |
| [2016-01-16 22:38:22] |
Refer to the documentation for Formula Source Sheet Number to understand this behavior. Although, from our perspective this is all kind of vague so we do not fully understanding what you are doing and what is happening. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-16 22:39:16
