Date/Time: Sat, 19 Sep 2026 14:02:15 +0000
Bar Range Function
View Count: 1586
| [2016-01-15 15:52:00] |
| Johnny - Posts: 99 |
Hi, is there an ACSIL function that calculates the maximum/minimum bar range over a specified number of bars?
| [2016-01-15 17:30:46] |
Not that we can think of. But this is easy enough for you to calculate.
| [2016-01-15 19:14:03] |
I have tried to create my own function for this but I get the error: a function-definition is not allowed here before '{' token.
| [2016-01-15 19:21:46] |
Obviously this is meaningless to us without actually seeing the code.
| [2016-01-15 20:08:31] |
Here's the code: int Index = sc.Index; SCFloatArrayRef High = sc.High; SCFloatArrayRef Low = sc.Low; float MaxBarRange(int NumberOfBars, int Shift) { if(Shift <= Index) { MaxValue = High[Index - Shift] - Low[Index - Shift]; for(int i = Index - Shift - 1; i >= 0 && i > Index - Shift - NumberOfBars; i--) { if(High - Low > MaxValue) MaxValue = High - Low; } return MaxValue; } } I also get the error: expected '}' at end of input. |
| [2016-01-15 20:34:19] |
This code seems fine: float MaxBarRange(int NumberOfBars, int Shift)
{ if(Shift <= Index) { MaxValue = High[Index - Shift] - Low[Index - Shift]; for(int i = Index - Shift - 1; i >= 0 && i > Index - Shift - NumberOfBars; i--) { if(High - Low > MaxValue) MaxValue = High - Low; } return MaxValue; } } Therefore, just make sure that it is located above the function where it is being called from and we would not expect there to be a compiler error. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
