Date/Time: Wed, 28 Oct 2026 12:55:46 +0000
Singapore Index issues
View Count: 1126
| [2016-01-15 11:08:22] |
| User457299 - Posts: 38 |
I am interested in MSCI Singapore Index and and Straits Time Index, both are under SIMEX. I would like to know how to get both the intraday data as well as the historical data. I am not able to get any intraday data as the chart is blank, as for the historical data I only manage to get dots. Below is the log. Thanks. Software version: 1336 | 2016-01-15 18:55:38 Uses New Spreadsheets | 2016-01-15 18:55:38 Usage end date: 2016-01-24 | 2016-01-15 18:55:38 Enabled for: Advanced Features. | 2016-01-15 18:55:38 Enabled for: Sierra Chart Historical Data Service. | 2016-01-15 18:55:38 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-01-15 18:55:38 Current selected Data/Trading service: SC Data - All Services | 2016-01-15 18:55:38 Chart Update Interval: 500 | 2016-01-15 18:55:38 Time Zone: +08:00:00 (HKT+08) | 2016-01-15 18:55:38 2016-01-15 18:55:38 Local computer time | 2016-01-15 18:55:38 2016-01-15 10:55:38 Local computer time in UTC | 2016-01-15 18:55:38 2016-01-15 18:55:38 Local computer time in SC Time Zone | 2016-01-15 18:55:38 2016-01-14 22:52:26 Server time in UTC | 2016-01-15 18:55:38 Local computer UTC time and Server UTC time difference: 2 seconds. | 2016-01-15 18:55:38 Program path: C:\SierraChart\ | 2016-01-15 18:55:38 Data Files path: C:\SierraChart\Data\ | 2016-01-15 18:55:38 OS Version Number: 6.2 | 2016-01-15 18:55:38 Locale Information: C | 2016-01-15 18:55:38 SVF16 1 Min #8 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\SVF16.scid | 2016-01-15 18:55:54 VSH16 1 Min #10 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\VSH16.scid | 2016-01-15 18:56:21 |
| [2016-01-15 19:38:38] |
This means that Intraday data is not available for these particular symbols. What you see in the Historical daily chart is going to be correct. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
