Date/Time: Wed, 28 Oct 2026 12:55:45 +0000
Global variable
View Count: 1744
| [2016-01-14 20:21:04] |
| ertrader - Posts: 698 |
Hi Support... I'm trying to create a global variable using the code in documenation: #include "SierraChart.h" SCDLLName("StudiesFileName") //This is a global integer variable int g_GlobalIntegerVariable; SCSFExport scsf_StudyFunction { if (sc.SetDefaults) { sc.FreeDLL = FALSE; } } When I try to compile, I get the following error: -- Starting build of Custom Studies Source files: GlobalVariables.cpp. -- 14:16:37 "C:\SierraChart\CPPCompiler\bin\g++.exe" "C:\SierraChart\ACS_Source\GlobalVariables.cpp" -march=i686 -mtune=i686 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -std=gnu++11 -o "C:\files\Sierra_Data\GlobalVariables.dll" C:\SierraChart\ACS_Source\GlobalVariables.cpp:7:12: error: variable or field 'scsf_StudyFunction' declared void SCSFExport scsf_StudyFunction ^ C:\SierraChart\ACS_Source\GlobalVariables.cpp:9:5: error: expected primary-expression before 'if' if (sc.SetDefaults) ^ C:\SierraChart\ACS_Source\GlobalVariables.cpp:9:5: error: expected '}' before 'if' C:\SierraChart\ACS_Source\GlobalVariables.cpp:14:1: error: expected declaration before '}' token } ^ -- End of Build -- 14:16:38 Can you please let me know what am I doing wrong? Thank you! Date Time Of Last Edit: 2016-01-14 20:22:31
| [2016-01-14 20:21:50] |
http://www.sierrachart.com/index.php?page=doc/doc_ACSILProgrammingConcepts.html#GlobalVariables
| [2016-01-15 03:49:30] |
The code example has been corrected. Reload that page for the updated example. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
