Date/Time: Wed, 28 Oct 2026 11:59:29 +0000
Chart Grid
View Count: 947
| [2016-01-12 17:17:04] |
| User948305 - Posts: 21 |
I use chart grid in ES intraday chart. Currently it's 2 points between 2 horizontal lines, how can I change it to 1 point? thanks
| [2016-01-12 18:34:00] |
You can do this by changing the Scale Increment in the Scale Settings: Chart Scale and Scale Adjusting Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
