Date/Time: Wed, 28 Oct 2026 11:59:25 +0000
HOD and LOD on tradeDOM?
View Count: 2457
| [2016-01-11 16:04:17] |
| trader1 - Posts: 128 |
Hi, I used to see the high and low of the day on my trade DOM. Can you please tell me how to display that on the DOM? Thanks. |
| [2016-01-11 17:51:23] |
I don't see that study on the DOM, just on regular charts.
| [2016-01-11 18:11:33] |
Check to make sure these are enabled and the color settings for them. This is documented on this page here: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM The settings are: Trade DOM Daily High/Low Line Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-01-12 17:33:38] |
Hi, I have these set as you suggest, yet they do not appear on the trade DOM. |
| [2016-01-12 17:57:14] |
Did you enable the "Enable" checkbox beside these in Global Settings >> Graphics Settings. Trade DOM Daily High Line Trade DOM Daily Low Line Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-01-12 18:01:28] |
yes
| [2016-01-12 18:05:45] |
here is a screen shot
| Attachment Deleted. |
| [2016-01-12 18:16:42] |
On the Trade DOM, go to Chart >> Graphics Settings, make sure the "Use Global Graphics Settings" option is enabled.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-12 18:17:00
| [2016-01-12 20:50:01] |
Okay, thanks. Actually it is better for me just to set it on the trade DOM, but it solves my problem.
