Date/Time: Wed, 28 Oct 2026 12:06:14 +0000
Quick change of chart period doesn't work if chart detached
View Count: 909
| [2016-01-09 22:49:33] |
| Viacheslav Malafeev - Posts: 88 |
As long as the chart window is non-detached, I can quickly change bar period from keyboard. As soon as I detach chart from main window, SC won't allow me to type anything in the window header to change chart period. This is an untypical behaviour I haven't come across before. I am not applying any drawing tools, etc. when I detach the window. Please help. |
| [2016-01-09 23:20:59] |
We see a problem with this. We are checking on it now.
| [2016-01-10 00:55:23] |
We have solved this. Update Sierra Chart with Help >> Download Prerelease. The version number is the same. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
