Date/Time: Wed, 28 Oct 2026 11:14:48 +0000
Numberbars bid/ask 'numbers' hard to read
View Count: 1074
| [2016-01-05 14:22:07] |
| Mistic - Posts: 76 |
I've attached an example photo. As you can see numbers are cut off at the top and hard to read. I tried the spacing buttons but only made it worse. How do i make the numbers more spaced out and easier to read?
| [2016-01-05 14:56:12] |
| Kefir - Posts: 34 |
Hi, did you try to right-click on the price ladder an use Interactive Scale Range? |
| [2016-01-05 14:59:10] |
No. That helped. Thanks.
| [2016-01-05 16:14:44] |
Refer to the documentation for this here: http://www.sierrachart.com/index.php?page=doc/doc_NumbersBars.php#Scaling Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
