Date/Time: Tue, 24 Nov 2026 09:33:35 +0000
Historical Intraday Options Tick Data
View Count: 2305
[2016-01-05 04:18:10]
User760942 - Posts: 120
Hi SC,
Do either of your data service plans below come with Historical Intraday Options Tick Data from the CME Group and/or CBOE?
http://www.sierrachart.com/index.php?page=doc/SierraChartHistoricalData.php
http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php
Regards
[2016-01-05 06:01:06]
For the Sierra Chart Historical Data Service, the futures options symbol format is documented here:
https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php#FuturesOptions
See if you can get Intraday data for an option. If you can, then give us one of those symbols and we will see if tick by tick data is available.
Date Time Of Last Edit: 2016-01-05 06:02:17
[2016-01-05 07:07:20]
I was able to get historical daily data for ESH2010C.
However, I could not get historical Intraday data for ESH2010C.
Does this mean Intraday data for Options is not available?
[2016-01-05 08:01:03]
Yes that is what it means.
Not sure if Barchart will start offering this when they have their new Open Feed available.
We ourselves have the technical capability to offer CME options, but it is just one of those things that has to be set up on our side.
So one way or another longer-term this will be available.
[2016-01-05 20:08:12]
Sounds good. Three questions.
1. Do you happen to know when Barnhart will have their "Open Feed" available (and integrated with SC)?
2.
Do you know when you'll be offering this?
3. Do you know if I can import this data into SC from any of the data providers your connected to (such as CQG, TT, Rithmic and so on)? I can reach out to them directly if your not sure.
[2016-01-05 21:08:00]
1. Not sure.
2. Not sure. It will not be anytime soon.
3. CQG and Rithmic do support futures options.
[2016-01-05 21:33:58]
Regarding item 2, I'm happy to pay you to expedite this if possible.
I'm guessing you don't have the time, but figured i'd ask. Please private message quote if interested.
[2016-01-06 02:39:03]
It is not something we have time for now.
[2016-11-22 15:14:33]
hanro - Posts: 10
Checking to see if there's an update to this.
Wondering if SC is capable of historical options data via these Barchart APIs:
- getFuturesOptions
- getSpecialOptions
- getEquityOptionsIntraday
[2016-11-22 18:11:40]
Futures options are supported. Refer to:
http://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php#FuturesOptions
We are checking to see if historical equity options data is available. When we hear back we will let you know.
[2016-11-22 18:23:21]
hanro - Posts: 10
Thanks for the update. I believe SC currently supports the basic price, bid/ask, volume for options, correct?
The specific Barchart API I refer to above (getFuturesOptions, etc) returns the Futures Option Greeks which is especially valuable. Any idea if this greeks data will be accessible through SC?
[2016-11-22 18:35:27]
Sierra Chart supports historical price data from Barchart for options. We do not think that includes the bid and ask prices.
There are definitely no plans for this.
[2019-06-06 22:10:50]
Chad - Posts: 247
Hi @SCE, has there been any expansion of historical futures options data offered, into intraday tick data for any of the CME Group exchanges?
Date Time Of Last Edit: 2019-06-06 22:13:23
[2019-06-07 02:05:56]
Yes this is supported. Refer to:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#FuturesOptions
