Date/Time: Wed, 28 Oct 2026 12:07:03 +0000
Trade Activity Log Question
View Count: 1116
| [2016-01-04 15:27:55] |
| trumpy - Posts: 37 |
Hi, Is it possible to filter the trade stats report on a particular Attached Order strategy? For instance I have an attached order strategy called Crude Breakout and I'd like to filter the trade stats to only see these orders using the Attached orders. Thanks, Scott |
| [2016-01-04 18:12:21] |
No, this is not supported and there are definitely no plans for this. We do not know whether this is live or simulated trading. If you doing simulated trading, whenever you are using a particular Attached Order configuration choose a different Simulation account: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) This effectively will do the same thing by separating those orders into a different account that can be filtered. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-04 18:14:16
| [2016-01-06 17:37:40] |
Hi - Sorry I don't think I explained what I'm looking for very well. Disregard about filtering on accounts what I'm looking for is filtering by trade strategy. So I have multiple trade strategies for the one instrument using the same account. For instance an Attached Order strategy called Crude Oil Breakout and one called Crude Oil reversal. I would like a way to run a trade stats report on each of these separate attached order strategy's. Ninja Trader has this ability and they call is "group trades by ATM Strategy". Hope this makes more sense. If this is not possible can we please have this added to the development road-map. Thank you |
| [2016-01-06 19:15:27] |
There are definitely no plans for this. It is not something you should expect we would ever offer.
