Date/Time: Wed, 28 Oct 2026 11:14:57 +0000
Charts taking a long time to load
View Count: 1039
| [2016-01-04 11:11:44] |
| User97916 - Posts: 10 |
Hi, When I open Sierra my charts are taking longer than 20 minutes to load and I don't know why? Have 5 or 6 chartbooks but most only have 6 charts. I am sending you the message log. Would appreciate your help - Cathy
| [2016-01-04 17:54:56] |
20 minutes is a very very long time. It depends upon how much data is being loaded in those charts, but we would expect it should not take more than a minute. If a reasonable amount of data is loaded usually a Chartbook should open in less than 15 seconds. Refer to help topic 30: Http://www.sierrachart.com/index.php?page=doc/helpdetails30.html Also consider updating your computer hardware with a faster CPU and use a Solid State Drive. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-04 17:55:39
