Date/Time: Sun, 27 Sep 2026 11:48:33 +0000
How to modify close of Heikin Ashi bar
View Count: 2095
| [2015-12-27 18:55:27] |
| User380760 - Posts: 88 |
The normal close of Heikin Ashi bar is haClose=(Open+High+Low+Close)/4 but, I want the formula of the close of Heikin Ashi bar to be haClose = (Open+ High+ Low+ Close) / 4.0; haClose = (haClose + Close) / 2.0; Can I do it by not writing a C++ code? |
| [2015-12-27 19:06:36] |
The source code for the Heikin-Ashi study is provided and it can be modified. Refer to this page: http://www.sierrachart.com/index.php?page=doc/doc_BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-12-27 19:50:21] |
where is the source code?
| [2015-12-27 22:06:48] |
Follow the instructions here for this: http://www.sierrachart.com/index.php?page=doc/doc_BuildCustomStudiesDLL.html#SearchingSourceCodeBuiltIn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-12-28 00:18:37] |
okay, worked. thanks.
