Date/Time: Wed, 28 Oct 2026 11:14:51 +0000
Template for study in Sierra Chart
View Count: 1182
| [2015-12-26 08:36:53] |
| User69287 - Posts: 9 |
Hi guys, There is one thing in my mind. I am thinking about creating study, which after succeed any easy condition like reach any value on volume or any other study, to draw any marker, i. e. dot or something in my PA graph in the particular value. Basically just wanna see marker in my main graph when specific value of any study is reached. And i would like to ask you gyus, because suppose it is very often wish, there is any template, just to change study, value, marker... Am i right? Do you have anything like this? I would very appreciate your help, thanks a lot mates. Have a nice holidays and happy new year. |
| [2015-12-26 10:20:40] |
The Color Bar Based on Alert Condition study does this: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s245 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-12-26 17:38:16] |
Thanks for the answer. It is useful for sure, but not in my case. My point is to mark the price in that place, where the conditions are reached. Just dot or line whatever in this value. |
| [2015-12-27 02:04:24] |
This study can also do more than just color Chart bars. Refer to these two subsections: Drawing Arrows or Other Styles at the High or Low of Bars Coloring Subgraphs of Other Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
