Date/Time: Wed, 28 Oct 2026 10:28:09 +0000
custome spaced price axis
View Count: 996
[2015-12-23 17:54:17]
User12089 - Posts: 386
How can I configure a custom spaced price axis e.g. with price labels 20 points apart from each other - see attached example image
the question also includes the vertical and horizontal lines starting from the labels on the time and price axes and forming a grid on the chart
imagespaced price scale template.jpg / V - Attached On 2015-12-23 17:51:24 UTC - Size: 123.39 KB - 481 views
[2015-12-24 20:04:05]
You need to set the Scale Increment for the chart. Refer to:
http://www.sierrachart.com/index.php?page=doc/doc_Scaling.html
And also refer to the Horizontal and Vertical Grid:
http://www.sierrachart.com/index.php?page=doc/doc_ChartMenu.html#HorizontalGrid
