Date/Time: Wed, 28 Oct 2026 10:27:18 +0000
Tick and Minute Chart synchronization
View Count: 1115
[2015-12-23 16:06:09]
User37799 - Posts: 6
I have a tick chart that I am trying to synchronize with my minute chart. I am trying to draw a vertical lines and study overlays on the tick chart at 1 minute intervals BUT the lines and overlays are being drawn anywhere from :05-:13sec after the new minute turns over. How to I get the lines and study overlays to post exactly when the minute turns over?
[2015-12-23 19:15:12]
This is hard for us to understand from our perspective.
We need a very precise example of the source and destination bar Date-Times and what is being copied from one chart to another and the method by which that is being done.
If you are using the Study/Price Overlay study, refer to the documentation for it here:
Study/Price Overlay Study
The various Input settings should accomplish what you want. However, if there is no chart bar in the destination chart that starts exactly at zero seconds of a minute, then what you want to do is totally impossible.
