Date/Time: Wed, 28 Oct 2026 10:27:41 +0000
Problem with color background
View Count: 1173
[2015-12-23 01:14:31]
User380760 - Posts: 88
I want to color the background based on some conditions in longer time frame. But the problem is that it seems the alert was only checked at the start or end bar of the longest time frame. See sample image. This is not very helpful. I need the alert to be check on every bar of the current time frame. How can I do it?
image2015-12-22_20-11-32.png / V - Attached On 2015-12-23 01:14:27 UTC - Size: 8.46 KB - 389 views
[2015-12-23 01:33:18]
We do not understand this.
If you are using the Color Background Based on Alert Condition study, then you need to resolve whatever problem you have with the formula. We do not know what the problem is.
