Date/Time: Tue, 28 May 2024 17:13:53 +0000
Re Please start a new support request with your ideas
View Count: 2967
[2016-09-07 19:26:28] |
Sebastian_M - Posts: 70 |
Hey S.C.E again I have a request for the DOM, as you added a highlight to the Last Traded Recent Bid Volume Background I have another request that I am willing to PAY for: Highlight Cumulative last size with first initial uptick in blue, then white there after, first initial downtick in red, then white there after. Can I stack the Cumulative last size on top of the volume at price? Please let me know as I need this for the end of the month. Thank you in advance. Sebastian |
[2016-09-10 10:56:36] |
We need to get back to you about this.
[2016-10-27 11:04:21] |
Hey Engineering, I am still waiting for a reply. Thank you |
[2016-10-27 17:21:46] |
We can do this: Highlight Cumulative last size with first initial uptick in blue, then white there after, first initial downtick in red, then white there after. Not sure how soon we can get to it. You really would need to allow about 30 days because we are very busy but we can probably work it in. Can I stack the Cumulative last size on top of the volume at price? This is not supported. Are you referring to displaying this above the Volume by Price study?
[2016-10-27 17:29:25] |
Hello, Thanks for the reply. Highlight Cumulative last size with first initial uptick in blue, then white there after, first initial downtick in red, then white there after. Not sure how soon we can get to it. You really would need to allow about 30 days because we are very busy but we can probably work it in.Yes please, I really need this and will pay. Can I stack the Cumulative last size on top of the volume at price? This is not supported. Are you referring to displaying this above the Volume by Price study? Yes I was, would be helpful to me, but the above is really important. Thank you in advance. Regards Sebastian |
[2016-10-28 00:27:12] |
Acro - Posts: 436 |
Sebastian, Your order flow suggestions are usually very good. I'm trying to work out how this will appear. If I understand correctly, the cumulative last size column would remain as it currently is the Chart DOM or Trade DOM but there would now be a red or green color or highlight on any change of direction ? So, we'd get a lot of color during a congestion phase and no color during a move ? PS I eagerly await the pulling/stacking column Sierra are implementing in the next month as that would also go very well with this suggestion Date Time Of Last Edit: 2016-10-28 00:28:02
[2016-10-28 06:56:24] |
Acro Here is a video so you can see where I am coming from, then hopefully better understand. https://youtu.be/Z9tJMMKRIQI Engineering, this is how it should look. Regards Sebastian |
[2016-10-28 08:20:40] |
Acro - Posts: 436 |
I get you Sebastian. Amongst other things it illustrates absorption, and highlights the speed/rhythm of up and down ticks |
[2016-10-30 13:56:05] |
S.C.E If it could look like this, then that would be better as you could see the bid/ask when active as well. Regards Sebastian |
Sierra chart DOM highlight.jpg / V - Attached On 2016-10-30 13:54:43 UTC - Size: 14.31 KB - 348 views |
[2016-10-30 15:14:17] |
Engineering I have created a video of why I want this feature so you understand. Thanks I have deleted the video. Date Time Of Last Edit: 2016-10-31 08:57:54
[2016-10-31 08:24:26] |
We looked at the video. There is nothing there that is really helpful to us. We already know what you want. The only question we have is what is the number within the parentheses? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-10-31 08:24:53
[2016-10-31 08:57:08] |
Hello S.C.E, The only question we have is what is the number within the parentheses?
Ignore that, it is the non accumulated volume, and it is a unnecessary distraction.I am really looking forward to this feature. Let me know the cost, so I can pay immediately. Regards Sebastian |
[2016-10-31 09:28:23] |
Acro - Posts: 436 |
Sebastian, I still think the proposed pulling/stacking column will go really well with this feature. Eg in your video where you had the absorption the column would have shown the significant stacking taking place. |
[2016-10-31 09:31:37] |
Hey Acro, This should make an exciting addition to our arsenal. I will look out for it. Thanks |
[2016-10-31 10:33:23] |
Hey Acro, Will this be the same as Jigsaw, with the columns being next to the bid/offer? Regards Sebastian |
[2016-10-31 11:05:57] |
Acro - Posts: 436 |
Hi Sebastian, With the ChartDOM or TradeDOM, you can arrange your columns in any order so if that is what you want you can achieve it when these features are added. In my opinion, with these two features and the ability to market replay the DOM properly including each of these columns at some stage (hopefully within six months) this is better than Jigsaw. At the moment I only use Jigsaw (inside NT8) for market replay of key order flow activity. |
[2016-11-17 18:36:25] |
Regarding the coloring of the Cumulative Last Size/Quantity market data column based upon the initial up or down tick, this will be out in a couple of days.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-11-17 18:36:40
[2016-11-17 18:42:27] |
Hello S.C.E Thank you very much. What is the charge? Regards Sebastian |
[2016-11-17 18:51:31] |
Nothing being that this is part of development we are currently doing.
[2016-11-17 18:53:09] |
Thank you. I can help you with order flow, as I trade it. Regards Sebastian |
[2016-11-17 18:57:57] |
You can disregard my request about putting volume on top of Volume profile. Too much hassle. Thanks |
[2016-11-18 16:12:03] |
Acro - Posts: 436 |
Sebastian, This is now in 1487 (Prerelease). Thanks Sierra, I like your implementation of Sebastian's idea. |
[2016-11-18 16:51:54] |
Hey Acro, Many thanks, I will wait until it becomes post pre-release. And of course many thanks S.C.E Regards Sebastian |
[2017-01-05 09:44:29] |
Hi Engineering, Would it be possible to make the highlight on cumlative volume a background please, this what I originally wanted, as per the video I uploaded, I have used the highlight text, but it does not keep your eye on the cumlative volume. I have created some images. Perhaps I did not make it clear in my first request. Is it possible to have a base background highight whilst keeping the initial up color and initial down color please? I am willing to pay. I know this is a nuisance, but I need to get this correct. |
SC DOM request background white.jpg / V - Attached On 2017-01-05 09:43:21 UTC - Size: 14.63 KB - 297 views SC DOM request background green.jpg / V - Attached On 2017-01-05 09:43:30 UTC - Size: 6.56 KB - 243 views SC DOM request background red.jpg / V - Attached On 2017-01-05 09:43:36 UTC - Size: 7.18 KB - 256 views |
[2017-01-10 22:35:19] |
We have to get back to you about this. Please allow about a month.
[2017-01-13 16:09:07] |
Hey Sierra Chart engineering, I have moved my account to a Trading Technology's broker S5trading, I just got too frustrated in waiting. So I no longer need the above mods on the cummlative volume, but I know at least one person would still want it. I am now on the same side as the sharks. If others want this mod, then please let S.C.E know. Thanks for all the previous work you have done for me. |
TT Cloud workspace.jpg / V - Attached On 2017-01-13 16:07:48 UTC - Size: 320.1 KB - 345 views |
