Date/Time: Sun, 20 Sep 2026 13:24:54 +0000
Problem with history data
View Count: 1825
[2013-06-23 15:06:22]
User23927 - Posts: 1
I bought software for three months, so I tried it. However, I have a problem with the history of plotted data. I keep getting data only for the last 30 days and I can not set a longer history. Please advice how to set up your software.
I use data from Interactive Brokers where my account. History data be set as follows: Global Settings - Data / Trade Service Settings - Max. Historical Intraday Days To Download - for 90 days. Furthermore, I set Chart - Chart Settings - Days To Display / Load - for 90 days.
Even if I set 90 days chart shows only 30 days.
Sending more screenshots setting.
Thank you for your response.
Milan Slez
imageSierra 1.png / V - Attached On 2013-06-23 15:00:17 UTC - Size: 157.21 KB - 766 views
imageSierra 2.png / V - Attached On 2013-06-23 15:00:30 UTC - Size: 154.76 KB - 773 views
[2013-06-24 07:50:24]
Please follow the instructions in help topic 42.1 here:
Http://www.sierrachart.com/index.php?l=doc/helpdetails42.html
Since you are using Interactive Brokers, you will be encountering "Pacing Violations" downloading 90 days of data. To solve this, refer to help topic 37 here:
Http://www.sierrachart.com/index.php?l=doc/helpdetails37.html
Date Time Of Last Edit: 2013-06-24 07:51:10
