Date/Time: Wed, 28 Oct 2026 09:25:12 +0000
SC / AMP
View Count: 994
| [2015-12-10 20:25:39] |
| tobi - Posts: 351 |
AMP offers SC as one of its trading/charting platforms. Is there a difference if I use SC over AMP or over a direct account with SC. If so, what are the differences? Date Time Of Last Edit: 2015-12-10 20:26:35
| [2015-12-10 21:09:39] |
| tobi - Posts: 351 |
Looking through the support board, it does seem that there are some differneces. So I'd rather stay with a direct SC account. One additional question though: Is it possible to use the data from AMP with a direct SC account? |
| [2015-12-10 23:07:01] |
Is it possible to use the data from AMP with a direct SC account? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
