Date/Time: Sat, 24 Oct 2026 16:17:45 +0000
Relative Performance Indicator
View Count: 2636
[2015-11-25 12:08:43]
Riche - Posts: 20
Is Sierra Chart able to create an indicator like this from Stockcharts.com?
Blue NYSE Indices is set a baseline (0%) while the other indices are referenced to it in % down/up.
imagePerfChart_Baseline.JPG / V - Attached On 2015-11-25 12:05:08 UTC - Size: 106 KB - 804 views
[2015-11-26 04:35:30]
We are not sure of all the details of the calculations they are doing.
However, certainly you should be able to do something like this.
Have a look at the following studies:
http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s325 (Percent Change since Open)
http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s74 (Overlay (Single-Line). This study you need to overlay all of the other charts on one chart.)
https://www.sierrachart.com/index.php?page=doc/doc_SpreadsheetStudy.html (Spreadsheet Study)
Date Time Of Last Edit: 2015-11-26 04:36:02
[2015-11-28 09:00:54]
Riche - Posts: 20
Able to simplify those 3 indicators into 1 indicators instead?
Meantime, how can I set the "Percent Change Since Open" to Weekly opening instead of Daily?
[2015-11-28 09:14:57]
This is not supported.
