Date/Time: Fri, 26 Apr 2024 16:45:04 +0000
Price Not Printing on AT Charts
View Count: 704
[2015-11-23 17:40:48] |
Refer to help topic 3 here: Http://www.sierrachart.com/index.php?page=doc/helpdetails3.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-23 18:11:27] |
Follow the instructions in help topic 3.4: https://www.sierrachart.com/index.php?page=doc/helpdetails3.html#h3.4 And tell us whether real-time data is being received for the symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-23 18:27:55] |
Therefore, one of the other items must be the reason for the problem. Carefully go through them again: Http://www.sierrachart.com/index.php?page=doc/helpdetails3.html Or as a simple solution just close the chart and open a new one. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
