Date/Time: Wed, 28 Oct 2026 07:48:57 +0000
Type Text Tool
View Count: 2073
| [2015-11-19 07:39:42] |
| User21339 - Posts: 61 |
I am constantly naming pivots P1 - P9. It is very cumbersome having to type each one every time. Is there a way i can save them as perhaps shortcuts or even as configs that i can recall quickly? Or any other suggestion welcome to make this task simpler. |
| [2015-11-20 00:16:04] |
| User742717 Mike - Posts: 86 |
Some tools have labels displayed, ie lines You can put P1-P8 on the labels of the tool and switch it via shortcut or toolbar etc.. hope that helped. |
| [2015-11-20 01:51:06] |
You probably will want to use the Custom Text Drawing tool configurations: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#CustomTextDrawingToolBarButtons Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-20 01:54:02
| [2015-11-20 06:44:52] |
brilliant. does the job perfectly.. took a while for me to figure out how to set it up.. It's exactly what i needed. many thanks.
