Date/Time: Wed, 28 Oct 2026 19:58:32 +0000
Compact Tool Values Box
View Count: 1794
| [2015-11-10 09:31:11] |
| User842703 - Posts: 55 |
I have this box enabled on one chartbook and set it so that it hides with a click on the chart which also turns off the crosshair. However when opening a new chartbook this box is replicated in the same place and if I move it then it is also moved in the original chartbook. How do you turn off this synchronisation?
| [2015-11-10 09:37:24] |
Refer to the documentation for this here: Chart Drawing Tools: Compact Tool Values Window Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-11-10 10:11:26] |
Yes I had read that and have now figured out how to alter/move it separately for each chart, but using the Windows menu to turn it off in one chartbook automatically turns it off in the other and I can't find any reference to making the chartbooks independent in this regard so that it is on in one and off in another. Even turning off the Display Values option in Chart Settings still leaves a small box with the Y value, date and Time.
| [2015-11-10 11:30:22] |
Yes this is true. Showing the Compact Tool Values Window is not Chartbook specific. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-03-25 23:22:31] |
| kinghat - Posts: 120 |
is it possible to have the compact values box come up at the same spot on only the chart im clicking on? i want it located in the top left but a little bit lower than the default top left position. also i only want it to show up on the chart that im clicking on and not elsewhere.
| [2016-03-26 00:03:43] |
Yes of course. Refer to the documentation: Chart Drawing Tools: Compact Tool Values Window Always try to refer to the documentation before posting here. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-26 01:03:45
| [2016-03-26 02:01:58] |
i have read the docs and searched the forum before posting otherwise i wouldnt be asking. i have some charts that the CTV displays on and some charts show it on a totally different chart when i have the 'save CTV window for each chart' option on. so im not sure if im missing something here or if something is wrong. ive posted some images.
| [2016-03-28 20:30:40] |
We apologize for the delay. We need to write up documentation for this and it will be done today.
| [2016-03-31 10:55:44] |
Here is the relevant documentation: Chart Drawing Tools: Remembering the Position of the Compact Tool Values Window for Each Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-03-31 14:13:45] |
thanks guys!
| [2016-03-31 17:53:28] |
i think a good option to activate the 'Compact Tool Values Window' would be middle mouse click and it would either go to the normal position or the saved per chart position or you could even have it displaced or offset and floating around your mouse pointer. that would be the best way for the CTV window to work.
| [2016-03-31 18:21:52] |
This is not how it is designed and it will not change. The documentation explains how it is designed to work. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-31 18:22:04
