Date/Time: Wed, 28 Oct 2026 06:00:08 +0000
ASCIL: How to draw on top (not under) the candlestick bar?
View Count: 1788
| [2015-10-29 10:56:50] |
| User129630 - Posts: 22 |
When I draw a line (or a marker) on region 0 where the candlestick chart is resided, the drawings got drawn underneath the candlesticks, and hence not visible. How to make my drawings topmost, on top of everything (candlesticks, lines and others) so the drawings are visible. The following code is what I have, I don't know if I had missed some settings. Please advise. Thanks. s_UseTool Tool; Tool.ChartNumber = sc.ChartNumber; Tool.DrawingType = DRAWING_MARKER; Tool.MarkerType = MARKER_X; Tool.MarkerSize = 4; Tool.LineWidth = 2; Tool.AddMethod = UTAM_ADD_ALWAYS; Tool.Region = 0; Tool.BeginDateTime = DateTime; Tool.BeginValue = Value; Tool.Color = RGB(255, 0, 0); sc.UseTool(Tool); // Here we make the function call to add the marker |
| [2015-10-29 17:03:53] |
Refer to the Drawing Chart Drawings Above or Below Main Graph and Studies section here: http://www.sierrachart.com/index.php?page=doc/doc_ACSILDrawingTools.html#DrawingChartDrawingsOnTopOfOrUnderneath Sierra Chart Support Date Time Of Last Edit: 2015-10-31 12:20:56
| [2015-10-31 12:20:27] |
This section has been updated with additional information: http://www.sierrachart.com/index.php?page=doc/doc_ACSILDrawingTools.html#DrawingChartDrawingsOnTopOfOrUnderneath Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-31 12:20:40
