Date/Time: Wed, 28 Oct 2026 05:02:37 +0000
[User Discussion] - How to plot the number bar calculated values using like a moving average?
View Count: 1043
| [2015-10-26 19:41:53] |
| User767947 - Posts: 3 |
I like to plot the finish Ask Bid volumes in the number calculated values using a moving average.
| [2015-10-27 01:11:27] |
Add a Moving Average-Simple study to the chart and base it on the Numbers Bars Calculated Values study. Set the Length input for it to 1. Here are instructions for the study Based On setting: Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-27 01:12:03
